  • 5 Replies
  • 4369 Views
  • 3 Likes
yemi_del_este
I came home to 2 of 4 cameras flashing blue lights. Three are "offline" in the app. I have a doorbell and that seems to be functioning normally. The base station is "Online".
I power cycled the base station, but that didn't help. I power cycled one of the cams, and that didn't help either.
Read the following FAQ and let us know which LED flash matches your situation:
https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-camera-mean
I'd start by removing one camera from my account and try adding it back. Failing that attempt, remove all devices, including the base, and add them back as if new, starting with the base.
5 REPLIES 5
ShayneS
Hi @yemi_del_este
Are you still experiencing these symptoms?
yemi_del_este
Yes, but now an orange light is flashing.
A slow amber flash means a dead battery. Recharge it and see what happens.
yemi_del_este
They all have fresh charges.  Something is really wrong with my system.
  • 5 Replies
  • 4370 Views
  • 3 Likes
