I have the 2 camera Arlo 3 package and my batteries die every other day. I make sure they are fully charged, my video mode is on full, my sensitivity is on 5, I have it set to best battery life, I get about 10 notifications a day, and it will still die after a day and a half. I just recharged it to 100% and after 4 hours I’m at 88%. This can’t be normal, can it?
5 REPLIES 5
How much recording or live viewing is done each day ?
None. Since I saw that my batteries are dying so quickly, I don’t check it at all.
SD7,
Do the cameras have poor signal strength? You might try relocating your SmartHub away from any other WiFi devices to eliminate the possibility of interference.
Both cameras have a strong strength.
SD7,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
