My base station went offline today had I can’t get it back online. All three lights are green, I have change the internet cable and rebooted the base station. I have removed the base from the app and readded it and still offline. I reset the base station to factory and removed it from the app again. I was able to readd it but it still show off line with green lights. Any suggestion would be appreciated.
Should be fixed - is it?
No it still showing offline
Try rebooting the base.
Tried that several times. And also reset to factory several time. I can re-add it to the app. I've even renamed it something different but still off line.
I see a base station online at the moment, is everything back to normal?
Yes everythings is good. came home yesterday and rebooted everything again and it came back online. Thanks
