Arlo unable to rename camera on installation of Pro3 - cannot continue
  • 2 Replies
  • 3642 Views
BethHo
I am having trouble connecting the camera to my base station on setup. It recognises camera but keep getting “unable to rename the camera, please try again” and then I cannot continue with setup.
The model I purchase was VMC4040P. It isn’t even a choice in the dropdown above.
I have been on hold to telephone support for 41 mins without success to even get to speak to someone!
BethHo
Perhaps but I didn’t have a computer at home! Finally spoke to someone at Arlo and we got there. Ended up manually syncing the camera to the Hub (pressing the hub sync and then pressing the camera sync button which is located on the camera itself not on the outer casing). Once this was manually synced, it then allowed me to add and change name etc.
Thanks for your help!
michaelkenward
Sensei Sensei
Sensei
Can you try using the browser interface to add the camera?
Just another user
BethHo
  • 2 Replies
  • 3643 Views
