Arlo pro3 floodlight camera
  • 7 Replies
  • 2042 Views
Roger1938
Why is Battery showing fully charged but in the colour AMBER ?
Roger1938
Reset has fixed the problem Many Many Thanks
7 REPLIES 7
Does the amber LED flash or is it solid? Are you sure the battery is charged? How?
Roger1938
Solid amber, tried several chargers and all say 100% charged
WHat happens if the battery is reinserted?
Roger1938
Removed battery then waited a while then re connected still the same amber charging battery light on solid.
Roger1938
Harley2003
Another fault has occurred.
camera will not work unless the outdoor magnet charging  cable is removed ?
  • 7 Replies
  • 2043 Views
