Why is Battery showing fully charged but in the colour AMBER ?
Reset has fixed the problem Many Many Thanks
Does the amber LED flash or is it solid? Are you sure the battery is charged? How?
Solid amber, tried several chargers and all say 100% charged
WHat happens if the battery is reinserted?
Removed battery then waited a while then re connected still the same amber charging battery light on solid.
Not normal so I'd try a a reset:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Another fault has occurred.
camera will not work unless the outdoor magnet charging cable is removed ?
