Hello,
I meet the connecting dropping issue every two day once I reconnect to base station.
Does anyone meet this issue as well?
This is my first time using Arlo products but seems like a terrible experience for me.
5 REPLIES 5
How far is the camera from the base?
How many bars are you seeing for signal strength?
one is 15 feet and another is 8 feet.
And both are one bar between camera and station
Are they in different rooms? If so, what is the wall construction?
Also, if there are windows on the line of sight - are they low-E glass?
Both cameras are in the outdoor and one concrete wall between base and camera.
Actually, one of them drop off every two days and take turns.
I need unplug battery and plug in again and connection is recovery.
Please help.
Please help.
Can you temporarily move one indoors (on the other side of that wall)?
Many concrete walls contain rebar (iron/steel), which could be blocking the signal.
