  • 1927 Views
Mazin968
Hi there,
I'm using Arlo pro 2 for over a year now with VMB4000 and recently got one additional Base Station VMB4500 with Arlo pro 3 to cover the back yard.
Now I'm having an issue that the pro 3 is not able to record locally and even i tried to purchase one of the available plans but it seems my country is not yet supported.
any solution here?
dcfox1
Do you have the 4500 base with the Pro3 or the 4540 smart hub that comes with them in a kit.  With the 4500 you need to eject the USB to view in a computer. With the 4540 you can use the app. Either way you need a 16GB or greater USB stick or drive to work. Not sure if you read this link in FAQ here.
What is Direct Storage Access and how do I use it? (arlo.com)
dcfox1
Mazin968
I have the 4500r2 .. this is the details i got in the device info from Arlo app.
In this case i have to purchase another base station 😞
But does the 4540 support Pro 2 ?
dcfox1
Yes it does.
What is the difference between each Arlo SmartHub and base station?
  • 1928 Views
