Arlo pro 3 camera won't load
  • 2 Replies
  • 1093 Views
Jrich50311
I have two Arlo pro 3 cameras that won't work.  It shows up on the Devices page but when you click on the play button it says "The request time out". It says it has a full wifi signal, and the battery is full. It does not get clips either.
I have another camera that works fine.
I'd start by removing the battery, waiting 10 seconds or so, and then reinserting it.
You could also try restarting the base station.
Garlic2022
Try
Reset those non working cameras to factory default and then resync them back to hub
once synced, then reboot your internet wifi router,
After wifi reset..lastly reboot your arlo base
  • 2 Replies
  • 1094 Views
