Your base is compatible with the Pro 3:
https://kb.arlo.com/000062253/Is-Arlo-Pro-3-backwards-compatible-with-my-existing-Arlo-system
The camera will work in the same way as your existing cameras. Any delay will be the same - there is always the connection to the servers and back. The cameras/base do not send you the alert - the servers do.
@Frag333 wrote: I need to understand if I can get around not using the smart plan.
If you were to purchase a new base (VMB5000 or VMB4540) you could use direct access to local storage. https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
@Frag333 wrote:
That could be an option. Are you able to view your library the same way using the app?
You can (the steps are in the kb article). But you can't view the local files from the web client.
You would also lose thumbnails, which is a problem for a lot of people.
You do need to either forward a port in your router or use a VPN to connect to your router in order to view the videos when you aren't connected to your hone wifi network.
@Frag333 wrote:
Might have to look into the Ring cameras.
AFAIK, Ring doesn't offer any storage for any camera unless you have a paid subscription.
