until i find a new camera system worth changing to, i also now use a memory stick without the cloud service (no point paying for something that doesnt work!), but for my main front camera i also pay for the cvr subscription which rarely has many issues, you do need permanent power though with using at least a genuine arlo plug as the after market plugs dont provide enough variable volts and creates havoc with cameras.
First you have to understand how Smart works. A video is recorded and sent to the servers for post-processing. The AI determines what it thinks the object that caused the recording and matches that against your settings in Smart Notifications. If there's no match, the video is discarded, otherwise it's sent to your library.
Use of local recordings is useful for those "missing" recordings since they're the same video that got sent out in the first place but no post-processing was done (they're local, not on the server). You can use these recordings to see what was recorded but discarded by Smart.
Smart isn't always - that's why you can donate a video (if it's in the library) and the local recordings are a good way to check. You can also deactivate any camera from Smart so you get all recordings as well as change what subjects you have selected in your account.
Just want to add that cloud activity zones work the same way.
As a clarification, Activity Zones are the only time video will be discarded after smart analytics takes place. Adjusting smart notification toggles will suppress push notifications but library recordings should still be present, see here for an example of how person notification works: How do I enable the Arlo Smart person detection feature?
@JamesC Thanks for clarifying. What you described is the way my system works, I get all smart recordings in the Cloud regardless of on or off just not the notifications for those that are off.
