I have a question. We recently upgraded are Arlo system and really like how they formatted everything. When we would disable the camera we would have an enable option on the screen and all you had to do was tap it and it would turn the camera back on. That option is no longer on the screen. You have go back in and turn it on. I'm just wondering if anybody else has had this happen to their cameras. Any suggestions on how to turn it back on?
Currently I see an "Enable Device" in the middle of the camera tile (on the devices screen) after I turn the camera off. Pressing that turns the camea back on. (Note I checked this with an Ultra on my iPhone - I don't have any Pro 3s now).
If you aren't seeing that, then likely you will at some point.
