  • 992 Views
pdill66
How do you get the video downloads to play? I download the clip as mp4 but when it attempts to play in the media player it returns a message the format is currently unsupported, or the file is corrupted. I have tried on my PC and phone and all downloads fail to play
What model phone?  What version of iOS/Android is it running?
As @Dannybear says, the issue is likely the HEVC codec (which Arlo uses for 2K and 4K recordings).  Start by installing the VLC media player on the PC, and confirm that it will play your media.
The Microsoft HEVC extension doesn't work with old PCs - it requires a 6th generation AMD or Intel processor or later.  FWIW, it doesn't just enable HEVC for Edge - it also enables it for the Windows Movie player, plus it adds support for a related photo format (HEIC) in Photos and some other programs (for instance, Paint).  Unfortunately Chrome and Firefox won't play HEVC, even with the extension.
Dannybear
The reason for the error is likely due to the hevc requirement.
You have to buy the windows codec from Microsoft to play in edge.
You could also use VLC app which is free.
pdill66
VLC install resolved the issue. Thanks
  • 993 Views
