Arlo Pro 3 mounts
I’ve bought two different mounts I have had professionally installed for my ultra pro 3 camera and one broke (picture attached). The other my installer said the the mounts are all weak and will rust very soon. Looking for help or ideas to replace my mounts for long lasting.
Almost any camera mount ( threaded ) will work for you ... the cameras use a 1/4-20 threaded hole which is the standard for camera mounts
