  • 1925 Views
Reeneb62
I am purchasing the Arlo pro 3 cameras and smart hub for work.  We do not want them to record nor do we want to store recordings.  Can this feature be disabled?
dcfox1
Yes for cloud recording you can delete them from app and web page. You can also use the Smart Hub with a usb drive inserted for free recordings.
https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
dcfox1
Yes under Rules for each camera in Modes. Pro3 does come with a three Month Smart Trial that has 30 day storage. Since you don't want recordings what is your plan for them? If it is live viewing they time out after 30 min and would drain battery fast unless plugged into AC power.
Reeneb62
Yes we would use them for live viewing as the managers may be offsite for extended periods of time.  When recording are we able to delete all recordings after being viewed ensuring there is no way for anyone else to view them?
dcfox1
  • 1926 Views
