I got two Arlo Pro 3 sets with two cams and one smart hub each.
After three month of trouble free experience I get an error message from one cam saying:
<<your arlo device has been disconnected from the mains. activity zones are currently disabled>>
However looking at the desktop of my Windows computer 10 and my iPad or iPhone the Arlo system give me different cams being affected. Furthermore all cams are connecteted either to the power adapter or to the solar panel.
Anybody else having this issue and how to fix it?
Contacting the community as Arlo is not reachable by eMail service...
After 3 months the trial runs out and your choice is to subscribe to a plan or not. Smart is part of the plan needed for zones to work. I guess I'm not 100% sure if using AC power gives you zones without a plan on the newer (>Pro 2) cameras. Note that the solar panel is just a trickle charger and will not give you features that AC power will.
Hi,
I have already signed in to a Smart plan so this shouldn't be an issue...
I just got off the phone with Arlo US support regarding this issue. The only way to get activity zones to work is by using the power adapter/cable they sell in the store. According to the support guy, no smart features will work on battery power without a subscription plan.
As already said I'm on a Smart subscription plan...
This could be hard to track down since different devices give you different displays. I would start by checking the Smart Notifications section of Settings to verify what cameras are activated. Maybe deactivate and then activate again. Removing and resyncing may also help. WOrst case, a full system reset may be needed.
7Andersons,
You can contact support through the methods listed here: Arlo Support Center
The development team is currently investigating reports of this error. I will provide an update when more information is available.
A recent update was deployed to the Arlo cloud that should address the accuracy of Activity Zones. This should improve accuracy by more reliably sending notifications only when motion occurs within defined zones. More work is being done to improve the behavior of Arlo Smart notifications and to fix the Activity Zones error that some users are seeing when not using an AC adapter (battery only). Stay tuned for future updates.
