I followed the instructions below using the correct type USB inserted into my base station. At first the recordings were accessible through my Arlo app on my phone, however a couple of days later I could not access the videos and received the message: "Videos stored on [name of my base station] are not available. Please check your connection settings" I removed the USB and reinserted it. The videos became accessible again. Then, a few days later, I am back to no access and the same error message. Any advice on how to rectify this issue is appreciated.
To enable Direct Storage Access:
- Launch the Arlo app on iOS or Android.
- Tap Settings > My Devices.
- Select a SmartHub.
- Tap Storage Settings.
- Tap the switch next to Record Locally.
Local storage is now activated on your Arlo device. - Tap the switch next to Direct Storage Access.
I've seen this occasionally. It really appears to be more of a display issue since force closing the app or waiting for some time seems to correct it. A reboot of the hub may help, too.
