Anyone has been constantly having issue with the pro3 camera? I have had the camera for less than 11 months and it keep going offline. I thought they were weatherproof camera as well and they are not. Any ideal on how to get it back online. I’m thinking about but another wireless camera brand.
Mine are outdoors, and I've had no issues. What problems are you seeing?
@rbell54 wrote:
it keep going offline. Any ideal on how to get it back online.
How far is it from the base? What signal strength are you seeing?
The warranty is 1 year, so if you think the camera is defective (particularly if you've seen water damage), you should probably contact support using the link in the upper right of the forum page.
