Just bought the kit. Stuck during installation as application doesn’t detect base station. I’ve tried factory reset to no avail. Led indicator on base is blue, I.e. supposedly connected to internet. Tried chat support, was told to call support. Can’t get through to support, just put on wait or being disconnected. Does anyone have suggestions for what I could try? Big thanks
Mike-99,
Have you made sure the device you're using to set up is on the same network as the Base Station/SmartHub?
Are you using a mobile device or a PC?
Are you using a VPN? If so, disable it during setup.
Thanks, but no, I’m not using a vpn
I would swap at the store to see if a different system works. You can also try a different location for setup, if practical.
Yes, you’re right. Spent too much time trying to make this work. Will ask for a refund and change to another more reliable brand.
