The Ultra 2 camera body will fit and lock into the Pro 3 case. to achieve a longer battery life, can the Pro 3 battery be used to power an Ultra 2 camera?
The Pro 3 battery is the same as the Ultra, so it can be used - but will not improve the battery life.
But you can purchase the XL upgrade kit.
