My Smarthub will not recognize my device.(cell phone). My Hub is connected via ethernet cable to an AirCube Isp. Light on my SmartHub is solid blue.
Thanks!
@YUCATANMAN wrote:
But don't I need a connection to the base so that I can later review my camera etc? Maybe I'm losing it! Lol....
No. The camera connects to the base over the closed wifi. The base is connected to your local network (and to the arlo cloud) over the ethernet connection to your router.
The app connects to the Arlo cloud - and when you are home, it can also connect to the base.
@YUCATANMAN wrote:
Thanks for the help, but not sure I'm understanding. The first step in installation is "plug in your ethernet cable". Step 2 is "plug in your power". Once you do that and press continue, it goes to a screen that say "Looking for your Arlo device. Give us a few minutes to look for any available base stations or hubs".
I wait about two minutes while it searches....
Have you just tried this from your phone app? Or have you also tried it in a PC browser (my.arlo.com)?
Thanks!
Not sure what you mean by "not recognize my device (cell phone)" Have you set up the system before or new system you are setting up? Can you see anything in the app? Have you tried viewing or setting it up on the web page my.arlo.com ? The solid blue light means you have an internet connection.
Are you following these steps in this video that is in the pinned FAQ here. Also try it on the web portal my.arlo.com
How-to Set Up Arlo Pro 3 Wire-Free Security Cameras - YouTube
@YUCATANMAN wrote:
But my phone won't connect to the base.
No, and that is by design. The phone should be connected to your home wifi network, not the base.
If you are having trouble on-boarding with the phone, then you could try using a PC browser (via my.arlo.com).
I wait about two minutes while it searches...It then says " No Arlo devices currently found".
That's as far as I get. My phone is connected to the wifi. But don't I need a connection to the base so that I can later review my camera etc? Maybe I'm losing it! Lol....
