Cannot get to recordings
  • 7 Replies
  • 2365 Views
Wegentryjr1
None of my recording show up. I’ll get a notice that there are new recordings, but nothing shows up..can’t even get to old recordings now. All I’ve done so far is to restart the base..no joy.
Wegentryjr1
It ended up being that the port changed somehow. I just made sure to open that port on my router. Thanks for the help!
7 REPLIES 7
dcfox1
Are you talking about cloud or local recordings? If cloud do you have a current subscription if your trial may have run out.
Wegentryjr1
Local recordings.
Wegentryjr1
Now that little line isn’t going across the top, but it shows I have no videos.
dcfox1
Have you removed and reinstalled the app, Your past post say you have IOS. I Just tried it and it worked.
Wegentryjr1
I have now removed and re-added the app and that was no help.
Wegentryjr1
You may want to set the DHCP server in your router to always assign the same IP address to your hub. That way reboots of the hub and/or router will always assign the same address and nothing changes for the port forwarding.
  • 7 Replies
  • 2366 Views
