I can no longer stream live video on my iPhone. I have updated my iPhone iOS to version 16.0 recently. Is there any compatibility issue with Arlo App and new iOS 16.0?
Yes, that works! I disabled Local 2K Live Streaming and it worked fine. Thanks StephenB. However I just spoke to Arlo Support. They said they are aware of this issue and currently working to resolve it. So for now, disable 2K Live Streaming would be a temporary solution.
If you have 2K livestreaming enabled on the phone, then disable it for now. FWIW, this is not an iOS 16 issue, the timing is coincidental.
