Arlo Pro 3 Mount
  • 1305 Views
mkheise
I have an Arlo Pro 3 Floodlight but when I moved, I forgot to take the mount off the garage. I cannot seem to find it online as a part they sell separately. Does anyone know if they sell them?
Check https://www.arlo.com/en-us/accessories.pro3.pro4 to see if that's what you need. There is also the various threaded mounts that use the standard 1/4"-20 thread you can use - there's zillions of them that should show up for a threaded camera mount.
Do you have the Pro 3 Floodlight, or the normal Pro 3?
@jguerdat is pointing you towards standard mounts that will work with the Pro 3.
But unfortunately the Floodlight has a non-standard mount, and Arlo does not sell it separately.
Yup, glossed right over the "floodlight" part...
  • 1306 Views
