Pro 3 outdoor charger
  • 1 Reply
  • 371 Views
12341
I’m installing my pro 3 floodlight camera, and waiting on the outdoor cord for a few more days. Does anyone know how wide the smallest end of the cord is? I need to drill a hole in the wall, because this will be a permanent mount.
The cable is thicker, but the connector is I think the same size as the indoor magnetic connector.  So if you drill a hole big enough for the indoor connector, you should be ok.
Note the outdoor "cable" is actually an integrated power adapter+cable.  So there is really only one end of the cable.
  • 1 Reply
  • 372 Views
