  • 1798 Views
Broomstick
I have two cameras.
Battery will not  charge in one of the cameras.  I remove the battery and put it back in, and the blue light blinks slowly for about 5 seconds and goes blank.  I then return the camera to the casing and connect the magnetic charge adapter.  Blue light blinks rapidly for 10-15 seconds and goes blank.  Check status on the app, no charging is taking place.
No issue (yet) with my second camera.
Broomstick
Cleaning the contacts did not work.
Solved the problem:
Removed the camera and battery from the casing.
Attached the charging adapter directly to the contacts on the camera - Used a rubber band.
Look at your app while adjusting the adapter and you'll see when proper contact is made and charging symbol appears.
It's a jerry rig, but it beats trying to communicate directly with Arlo.
Try wiping/cleaning the contacts on both the camera and charging cable. I've had to do that a few times.
Broomstick
I'll give it a shot and let you know.
Broomstick
Solved the problem:
  • 1799 Views
