  • 9 Replies
  • 2205 Views
haidong
It stopped working about a week ago. And my free subscription was expired three weeks ago. I'm not sure if it's related. I have submitted a support ticket three days ago, but no one responded.
Have you removed and resynced the camera? If connected to a base or hub, try rebooting that, too.
9 REPLIES 9
haidong
I enabled email notification too. Not work either.
Are you getting the recordings but no notifications?
haidong
That's correct. Recording is fine. No any notification. Feel disappointed. May return it to Costco if I can't find a solution in a few days. Spent a lot of time on it already.
haidong
Yes, I did. Reboot all of them. Not helpful. But this issue should not happen at all even if the reboot could fix the issue. Honestly I liked it in the beginning when I initially purchased it even though it's expensive. But now, I don't think it worths it. I think sooner or later everyone may have this issue. This is bad.
haidong,
Are you using iOS or Android? Have you checked your mobile device permissions to make sure the Arlo app is allowed to send push notificaitons?
haidong
I'm using apple IOS. Yes, I checked them. I even turned on the email notification just in case it's my phone or my iPad. None of them works.
haidong,
If you create a new custom mode with notifications enabled, do you still experience the same behavior?
haidong
Removing the device and adding back the device fixes the issue. Early I only tried to reboot the hub.
  • 9 Replies
  • 2206 Views
