The Arlo Pro 3 system works GREAT on my iPhone; however, it does NOT work at my.arlo.com. I can login to the web site and can see the cameras: however, if I try to click on a camera, I get a FRUSTRATING message stating that I need to UPDATE the ADOBE FLASH PLAYER. Well, my friends, you can update flash player until you turn blue-in-the -face, and it still doesn't stop the stupid message from popping up.
Some kind of way, I think Arlo gave me a tech support number of a bunch of charlatans. I remained on the phone over 4 hours with these clowns. They took control of my computer and were able to correct the problem, temporarily...Subsequently, when I got off the phone, the problem was back. I tried other browsers ( Opera, Firefox, etc.,) and the result was the same! H E L P!!!!!
If you use Fire Fox, as you go to Live view, a 'Lego" type icon appears on the left of address bar.
Click on this and all will work.
This is due to the browsers turning off Flash unless it is manually turn on... this will change by next year when flash will no longer be supported ( prob to html5 )
This is an almost daily query, so there is plenty of past knowledge on the archive.
Search Results – adobe flash firefox
Solved: Re: Flash Player and Arlo Go Video at the Cloud? - Arlo Communities
Cannot view Live Feeds - Flash problem AGAIN! - Arlo Communities
I do hope that you did not call a support number you found in a web search. It is almost certainly not Arlo.
Anyone can buy a listing on Google. Most of those sites are scam merchants who want your credit card details. Allowing them access to your computer is seriously dangerous.
Ten minutes here would have been quicker and safer.
Just another user
Respectfully:
- This is not a browser problem it's an ARLO problem that's continuing to use a deprecated and exploitable video player which is why browsers try to limit it as much as possible. There are fewer than 2% of global websites still using Flash, but Arlo continues to drag their feet. HTML5 isn't hard, Arlo just feels like it's not important right now.
- 'Lego' workarounds are *not* permanent, so imagine someone like me trying to explain to my 81yr old mother how to again view her cameras on her laptop (she doesn't own a smartphone). "You said Arlo was good, but if I can't see anything it's sh*t to me" was our last conversation.
@fishferbrains wrote:
This is due to the browsers turning off Flash unless it is manually turn on... this will change by next year when flash will no longer be supported ( prob to html5 )...
Of course. FWIW, Arlo has announced that they will switch to html5 before flash is removed from the browsers.
Everyone here will be happy when they do that - hopefully sooner rather than later.
"Everyone here will be happy when they do that - hopefully sooner rather than later."
I'm over $1200 into Arlo Pro/Pro2 cams and accessories and my mother over $700. You know what makes me happy? The fact that Wyze just released their "Complete Motion Capture" cloud service available for $1.49/month and selectable per camera (not an all or nothing thing). It's planned a web app that doesn't use Flash, the cameras are dirt cheap and their customer service is fantastic.
Arlo I wanted this level of service and customer focus from you for years.
Please Arlo, switch to HTML5 sooner then later. The world has known since 2017 that End of Life for Adobe Flash Player was going to be 2020. Why drag your feet? You are supposed to be a premiere company with superior product and support. Be the leader.
