@Surfstud wrote:
What is the difference between 2 and 3 should I make the upgrade from Arlo 2? Is the night vision better?
Pro 2 and Pro 3?
Pro 3 does not have free seven-day cloud storage.
The Data Sheets for these products in the document library can answer your questions about technical differences. Find them here:
Arlo - Security Cameras and Systems
Just another user
The biggest differences are
- The Pro3 is 2K (the Pro2 is 1080p)
- The Pro3 has a spotlight, so it can capture color recordings at night
- The Pro3 requires a subscription for cloud storage
I don't think so, though others might have different opinions on that.
I'm curious to hear reviews on the night vision as well. The difference in night vision between the Pro2 and the Ultra was HUGE, but the Ultra had so many other issues (worse signal strength, worse motion detection) that I ended up returning them and going back to my Pro2s. I'm curious if the Pro3 is a significant difference from the Pro2 or just an upgraded name to get people to buy new product.
See above. And read numerous messages here over recent months along the same lines.
Do you have any particular questions?
Just another user
