App delay
  • 7 Replies
  • 2501 Views
Markus71
Liebe alle
Seit dem Update, startet das App mit ca. 40 sekunden verzögerung. Hat dieses Problem auch noch jemand?
Love all
Since the update, the app starts with a delay of about 40 seconds. Does anyone else have this problem?
ShayneS
I have escalated your case & someone from support will be reaching out to you as soon as possible.
7 REPLIES 7
ShayneS
May I ask which version of the Arlo app you're using on Android or iOS?  and the troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Markus71
Guten Abend
Ich habe ein iPhone 15 pro Max.
Nur das starten geht extrem lange. Wenn ich im App bin, funktioniert alles einwandfrei.
Good evening
I have an iPhone 15 pro Max.
Only the start goes extremely long. When I'm in the app, everything works perfectly.
ShayneS
Is this when opening the App, the Home Screen takes time to load or is this when initiating a iive stream?
Markus71
Es betrifft beides.... App und Stream
ShayneS
On mobile data or WIFI?
Markus71
Egal, reagiert bei beiden gleich langsam
ShayneS
  • 7 Replies
  • 2502 Views
