Liebe alle
Seit dem Update, startet das App mit ca. 40 sekunden verzögerung. Hat dieses Problem auch noch jemand?
Love all
Since the update, the app starts with a delay of about 40 seconds. Does anyone else have this problem?
I have escalated your case & someone from support will be reaching out to you as soon as possible.
May I ask which version of the Arlo app you're using on Android or iOS? and the troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Guten Abend
Ich habe ein iPhone 15 pro Max.
Nur das starten geht extrem lange. Wenn ich im App bin, funktioniert alles einwandfrei.
Good evening
I have an iPhone 15 pro Max.
Only the start goes extremely long. When I'm in the app, everything works perfectly.
Is this when opening the App, the Home Screen takes time to load or is this when initiating a iive stream?
Es betrifft beides.... App und Stream
On mobile data or WIFI?
Egal, reagiert bei beiden gleich langsam
