Android app local feed
  • 5 Replies
  • 3501 Views
  • 2 Likes
Berd
Base VMB4540
Cameras Arlo pro 3
Arlo Android app version 5.6.2_28829 (Updated  03.19.25)
Android phone Galaxy s20+ Android 13
I was trying to figure out If the LOCAL Tab in the android app actually does anything. I would think it would be to view local recordings, however in order to do that I must go to Devices-Base-storage settings to view my local recordings.  Is this a known bug or is this just a place holder for future, or should it be working? attached are 2 screen shots of the error and the Feed screen
Arlo Screenshot_20250322_075954_Arlo Secure.jpgArlo Screenshot_20250322_081956_Arlo Secure.jpg
Berd
It was the VPN. I tried it on the wifi and switched over to cellular data and it worked on both.  It's weird as I checked it on my husbands phone (Identical to mine except he does not have a VPN) and it did not work on his either. Will try his again.
Thanks ShayneS
5 REPLIES 5
That is what it is supposed to do.  I use an iPhone myself, but some Android users have reported  that it works intermittantly for them.  So it is buggy at the moment.
Edinburgh_lad1
So, business as usual with Arlo. This brand is fast becoming associated with the words 'poor' and 'inadequate'.
ShayneS
@Berd
Is your phone connected to the local network and VPN disabled?
Berd
Thanks ShayneS
ShayneS
@Berd Thanks for the update.
  • 5 Replies
  • 3501 Views
  • 2 Likes
