AirPort Extreme/express
  • 6 Replies
  • 2522 Views
Retterr
How can I connect the cameras to Apple router and not have 2 routers? Where is Arlo tech support?
6 REPLIES 6
2 routers? Do you mean a base or hub? Or are you trying to connect via WiFi?
For support, have you used the Contact Support link at the bottom here?
michaelkenward
Sensei Sensei
Sensei
The Arlo hub is not a router.
Just another user
Retterr
Retterr
Yes I am connecting to my home Wi-Fi and would love to not have to use the hub
michaelkenward
Sensei Sensei
Sensei
The hub is the "front end" of your system. Your cameras will not work without the hub. It is effectively the wifi "bridge" that joins your cameras to your router.
Arlo does make cameras that do not need a hub, such as the Essentials and Pro 3 Floodlight, but they are new to the market. The Pro 3 cameras need the hub.
Just another user
Retterr
Does it need to be hard wired to my router or will it communicate wirelessly?
Thank you
  • 6 Replies
  • 2523 Views
