Arlo Pro 3 camera battery won't charge
Purchased set of 3 cameras and set them up with Arlo solar panels for charging. Two of them are fine, but one of them stopped charging off the solar panel. I brought it inside and plugged the camera with the battery inside into an outlet for several hours and it is still at zero charge. I've only had them a few months. Do I need a replacement battery or a new camera or is there a trick to getting it to charge?
Use the Contact Support link at the bottom here for a hardware problem.
Arlo case #41842013 created
I've attached proof of purchase from costco. I believe that satisfies all the information you requested, so please let me know how to get a replacement for this camera.
This is a user to user to user forum not official support. Once and a while an arlo moderator will respond but you should not post personal information here. If support requested it in an e-mail after you opened a case reply to that. No one from arlo requested that information here.
this is ridiculous - When I click on the link they send me I get an error. I did a search on the case number and it brought me here. They (Arlo) responded to this thread, so I posted it here. I'm getting pretty frustrated with Arlo support at this point....
daneaffr,
I've escalated your support ticket and requested a followup on the status. An agent will be reaching out to you to gather more information as soon as possible.
@JamesC - I spent a couple of hours with support via chat last night. Determined camera was bad and got an RMA - it is on it's way back to Arlo for a replacement. But thank you for following up!
