azgal77,
Are you able to tap the error and close the message?
Do you have activity zones set up?
Could you provide a screenshot?
azgal77,
Are you experiencing this issue when logging into the web client on a PC from https://my.arlo.com/#/login
I will reach out to you via private message to gather more information.
Shows " AC power has been disconnected from your Arlo device. Activity Zones are currently disabled". Works on my computed when I go to myArlo.com sign in but not on the app.
This is the same problem I'm having. The update didn't fix it!
I've tried with chat support all the things listed as in the other posts. Is does work when signing in on the computer using the myarlo.com login, just not the app on the phone.
Capital,
Have you tried removing and resyncing the camera? Does the error still occur after a resync?
Thanks!
I removed the cameras and then reinstalled them and it did work!
