  • 2 Replies
  • 1749 Views
dicko17
Hi there
i've set up my floodlight camera and the longest recording i can achieve is  seconds.
Things i've tried are:
read through many forum threads about the subject
I've changed the mounting position,
done motion detection test several times,
done camera positioning checks- (is strong)
changed the record length settings many times, in "mode"
changed the floodlight timing.
restarted device, lots.
Even deleted device and then re-added it
I've even walked around in circles for 20 seconds in front of it and it only recorded 2 seconds.
STILL no luck.
NOT HAPPY
any one else had any luck??
a couple things...
Make sure you are setting the record time in the MODE, not using the test feature.
Try and use a FIXED time over "record till motion stops" in the mode settings
dicko17
will do,
i'll let you know how it goes
  • 2 Replies
  • 1750 Views
