Solar charging VMA5600
@Ozitek wrote:
Hi just purchased the pro 3 flood light and would like to purchase the solar charging panel within couple of months.
Sorry, no idea if Arlo has come up with yet another mount size for the VMA5600. But I have the VMA3600 solar panel. (Not great with the large batteries in the floodlight, mine struggles to charge a camera.)
When I installed it, the screw holes were the same spacing as those on the Outdoor Security Mount (VMA1000). It may even be the same thing. Sadly, Arlo's documentation is silent on the issue.
Just another user
@Ozitek wrote:
Thanks yea support is not that great as well I didn’t know there was another solar product now I’m not sure if the one I mentioned works with pro 3
It should say in the literature. The difference is in the USB connector. Micro-usb or magnetic.
The pro 3 flood light has a magnetic connection. I have mine on a mains adapter.
Just another user
I didn't see the post where you mentioned the model, so I'm puzzled by that.
The VMA5600 is the only panel Arlo makes for the Pro 3.
Arlo Pro 3 Floodlight
