- English
- Floodlights
- Arlo Pro 3 Floodlight
- Re: Will my pro 3 floodlight camera work with my s...
I have a Pro2 Base station that is host to 2 pro2 cameras and a Pro3 Floodlight Camera.
I found the battery got low very quickly and bought a arlo solar Panel today because the pro3 floodlight Camera says its compatible with the arlo solar panel.
I have just unboxed the solar panel and it does not seem to be compatible. Can anyone answer of they are compatible?
There are two different panels since different cameras use different charging connectors (USB vs. magnetic). If you check the accessories here for the floodlight, you'll see that you need the VMA5600:
