  • 5 Replies
  • 6310 Views
Truth2121
I have 3 Pro 3 Floodlights and arlo essential spotlights cams and arlo video doorbell arlo base station.
Can I get another router etc to help the lag when opening my cams on the app?
5 REPLIES 5
You must not have the VMB3000 base, since it isn't compatible with your cameras.
You can get another base if you like (pairing some of the cameras to it, the rest to the existing base).  You can also try connecting cameras to your home wifi.
That could improve the signal strength/video quality, but it is unlikely to reduce the lag much.
Truth2121
Sorry I have the Base station
Vmb 4500r2.
I have the doorbell, one of the floodlight cams and one downstairs paired to the base station. So I should try to get another base station and maybe put it in the base station near my other cams?
Still will have the issue with the lag and time it takes to view the cam. I have issues even with the ones that are paired to the base station.
Wouk’s another router or mesh network help?
Vmb 4500r2.
Are you having any connection failures?  Or seeing any video corruption in the saved recordings (stalls, strange looking video)?
About how much lag are you seeing?
Truth2121
No not really having connection failures.  Just takes 20 to 25 seconds and sometimes longer for the video to come up.  No corruption in the videos.
Ok.
And once it does come up- how much lag are you seeing (delay between what you see on the screen and what is currently happening)?
  • 5 Replies
  • 6311 Views
