Arlo Floodlights.
Why do I keep getting this flag on my camera feed? ..... "Activity Zones are currently disabled. AC power has been disconnected from this device. Please reconnect the power source to the device."
That's due to either your existing AC power adapter, if any, being disconnected for some reason or you have at least one activity zone defined which requires that adapter to be connected. Check the camera settings to verify you don't have any defined. This also sounds like you don't have a subscription for the camera since that is needed for a camera that is not plugged in to be able to use those zones without external power (either the camera is powered externally so it can process the zone or a sub is needed to allow the servers to do so).
Thank you.
Yes, have zones and HAD a subscription but ended that to move to local storage. That's the issue.
@Wardrb wrote:Yes, have zones and HAD a subscription but ended that to move to local storage. That's the issue.
Well, activity zones on battery power is also a subscription feature.
Arlo Pro 3 Floodlight
