Pro 3 floodlight camera
My camera light was installed and working well over a year on the solar panel charger power and the unit had an error and wouldn't work. I took it down and charged it and it shows up on my devices but the camera won't connect it just sits there with the spinning wheel. I can remote turn on the light from the app no problem but it won't detect motion or activate the camera.
Could be a faulty camera but it may be fastest to remove the camera from your account and re-sync it.
Arlo Pro 3 Floodlight
