My pro three floodlight constantly alarms. If I leave the camera turned on, it will have alarmed at least 120 times within the hour and when I review the video log, there is no motion in the videos that would’ve caused or should have caused an alarm. Any suggestions my friends? I have set the sensitivity to almost 0 and it still alarms.
Where are you setting this? Many folks mistakenly think the setting is in the motion detection test - it's not there, you need to change it in the rules.
Also, check the rules and make sure audio detection is not enabled.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
I’ve looked and looked on the app and cannot find where I can adjust the sensitivity in the rules. How do I enter the rules mode? Thanks!
There's a mode control at the bottom of the app (and at the top of my.arlo.com).
Arlo Pro 3 Floodlight
