May I ask which troubleshooting steps you have performed so far? I don't want to suggest any methods you have previously performed.
Sure, you can provide a link to the shared recording if you like and I will have it investigated.
Is there a preferred way to do this.
Not really, it is up to you. You could get a shared link from the library (using my.arlo.com), or put a downloaded file into cloud storage (dropbox, google drive, icloud, etc). Then provide the link.
If you want to keep the video more private, you can send the link to @ShayneS in a private message (PM). There's an envelope link at the top right of the forum page that you can use to send the PM.
Thanks for the video, Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
I have the same problem with my floodlight. Last night I noticed a white noise sound with a clicking in between when live session is on and when it is a recorded video, it sounds like a helicopter in the background. I contacted but they did not give me a solution. I had to turn off the microphone because the sound is so annoying.
Any solution so far??
Hi
Bought this 2 weeks ago, heard weird ticking on audio every 3s but decided to ignore until unit started triggering a few days ago every few minutes even though it was NOT set to trigger on audio so I assumed it was faulty. Yesterday I replaced the unit with another new one under warrantee and same ticking noise every 3s and scratchy sounds in general. Other 4 x Pro 4 cameras work perfectly so there is nothing wrong with the base station or network or ambient sounds outside.
Anyone else had this and found a solution?
Mike
Hi @Ian4
Do you have the cameras connected to AC power by chance? or are the cameras running off battery power?
@Ian4
Does the same issue occur if you unplug the camera and try battery power only?
Hi,
Did you happen to see my post above?
Thank you
Which device are you using to stream your cameras? iOS/Android device?
@Ian4
Were you using a charging cable when experiencing this issue?
@peterw1956
Are you still experiencing the issue?
Yes I am. It happens on both my Spotlight cameras regardless if they are connected to power or on battery.
Thank you for the update, I have provided this to the dev team and will give another update as soon as I hear more.
Arlo Pro 3 Floodlight
