Pro 3 Floodlight battery
  • 4 Replies
  • 905 Views
FishTank
Hi
any tips on setting up a reminder to charge the battery, it has run flat on several occasions, and I missed fact that battery charge level was low…
The battery icon on Dashboard and Devices for each camera turns red when starting to run low. All you have to do is look at it and take action.
FishTank
Yes but I am not always looking at it, what I need is notification alert.
You should get an email when the battery drops below 15%. However, whenever opening the app the various cameras always show the battery icon  so a slight change in how you use the app helps mitigate the issue.
You could also schedule recharging using your phone's calendar - perhaps every month (depending on how quickly it typically needs charging).
  • 4 Replies
  • 906 Views
