Wi-Fi not Able to Detect my Flood Light
  • 177 Views
Carlos_101
The Arlo App works fine and I can setup the Flood Light, but when it comes to the Wi-Fi detecting the Flood Light it does not work.
The Gateway is from AT&T and I've been using it as a passthrough but the router is from TP-link. They say it's both 2.4 and 5.2 MHz.
I'm not sure how to proceed.
BrookeN
Which Floodlight are you trying to set up?
Carlos_101
Pro 3 Wire-Free Floodlight
Hardware: FB1001AerH6
Does your router let you temporarily turn off 5 Ghz wifi?
  • 178 Views
