  • 1 Reply
  • 1744 Views
jtweddle
In 2018, I installed an Arlo system of three cameras and the base station, as shown.  I am not sure which model it is.
Will a Pro 3 Floodlight Camera be compatible with this installation??
Thank you for your assistance.
Jim
Perth, Australia
Look at the base - there is a label on it that starts with VMB.  That will tell you the model number.
FWIW, if you open the camera housing and remove the battery(s) then you will also find the camera model.  You should do that, given that the EOL announcement.
The Pro (and original Arlo camera) loses free cloud storage on 1 April 2023, the Pro 2 loses it on 1 January 2024.
Base compatibility can be found here:
The floodlight can be connected directly to your home wifi (w/o a base), so you can use it even if it is not compatible with your base.  You will need a subscription for cloud storage after the trial ends (and all Arlo cameras will need a subscription for cloud storage once the EOL kicks in).
  • 1 Reply
  • 1745 Views
