Power Supply knocks cameras offline
I had a problem where my camera kept going off line and I could not figure it out until I moved the outdoor power supply to a new outdoor camera, and then that camera started going off line.
it turns out once I connect the power supply to the camera, the camera will stay online until it reaches 100% charge at which time the camera goes off-line and will not come back online until I remove the power supply.
has anyone else experienced this problem?
Can you try cleaning the contact points on the outdoor charger as well as the cameras contact points at the bottom with isopropyl alcohol and a cotton ball.
Arlo Pro 3 Floodlight
