  • 8 Replies
  • 1675 Views
Trikotnik
The Library doesn't show locally saved movies on USB of base station. I know that after 90 days you have to take a subscribtion or store the movie locally yourself. Ik choose to store local, but now the library does not show anymore my recordings of the floodlight.
8 REPLIES 8
FWIW, the ALS1101 | Arlo Security Light is not the Pro 3 floodlight (FB1001).
What base station are you using?
Trikotnik
Vmb4500r2
Trikotnik
I have also the Floodlight
The VMB4500 requires safely ejecting the drive and viewing the videos on a computer. Only the VMB4540 and 5000 hubs can be used via the app for direct viewing with the app.
Trikotnik
Will a (future) firmware make this possible again?
It never was possible with the VMB4500.
Do you actually have the VMB4540????
Trikotnik
No I have the VMB4500. I mean with again like the trail period of 3 months in the cloud.
@Trikotnik wrote:
I mean with again like the trial period of 3 months in the cloud.
You weren't seeing locally saved recordings during the trial period, just the cloud recordings.
The only way to get cloud recordings back is to get a subscription.  Arlo of course could change that, but I don't think that is likely.
  • 8 Replies
  • 1676 Views
