Arlo Pro Floodlight 3 - FB1001AerH4
Do they make an extra rechargeable battery for Arlo Pro Floodlight 3 cam?
@Truth2121 wrote:Do they make an extra rechargeable battery for Arlo Pro Floodlight 3 cam?
Yes. The XL battery (VMA5410-10000S ) will work. Though you'd get a camera shell with the VMA5410 that you don't use (since the same accessory allows up to upgrade the battery capacity in normal Pro 3/4 or Ultra).
Arlo Pro 3 Floodlight
