- English
- Floodlights
- Arlo Pro 3 Floodlight
- Re: How do I change the order of Videos in Library...
I have two camera, Using the ARLO app the Library has the motion videos are in a random order . How do I change the order to most recent?
They're not in random order - they're ordered according to when recording started. For instance, I have a doorbell camera as well as another aimed at the porch, both monitoring the same area. The other camera starts recording before the doorbell due to settings so it shows up before the doorbell video. You can verify this by downloading the videos and checking the filenames and/or metadata for the exact timing.
